Anyone got any experience with this stuff?
basically just transmitter then receiver for far away monitors n such, was wondering if it's any good
http://www.amazon.com/EP-WH3588-Wireless-Transmitter-Receiver-Support/dp/B009B6L2CE
Check out the build: Used to be Obot, now Lilith
Shameless: Me
https://linustechtips.com/topic/63255-wireless-hdmi/
Seems over priced. Never used any but i heard that if they are stand up ones and not the tiny dongles they should be fine.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
https://linustechtips.com/topic/63255-wireless-hdmi/#findComment-864883
d'oh this get side tracked very quickly xD
I'm well aware of the issue with wireless, I'm just wondering if anyone's familiar with this at all.
I personally only use cables, but was wondering about this since my long-thought to be gone dad bought this stuff for his work.
again, doesn't matter about $$$ or wireless, performance-wise, is it even acceptable?  I've never heard people actually using this kind of solution so :P
Shameless: Me
https://linustechtips.com/topic/63255-wireless-hdmi/#findComment-866356
I am too wondering if anyone has tested these. My PC is across the room from my TV, and I can't determine an acceptable way to run the HDMI cable I used to use with my projector to my flat panel. I used to run it on the ceiling but it looked horrible spanning a 12' ceiling.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
https://linustechtips.com/topic/63255-wireless-hdmi/#findComment-883865
I'll just ask my dad about his experience, hopefully it's good - because it would be neat to use it to avoid long cables in certain situations :)
Shameless: Me
https://linustechtips.com/topic/63255-wireless-hdmi/#findComment-886138
