Check the motherboard for a cmos battery like a oversized watch battery take that out for a few minutes pit it back in and test.
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/632449-pc-problems/#findComment-8164937
Resit the ram sticks one at a time and see if it posts.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/632449-pc-problems/#findComment-8164962
Boot loops are often a bios issue. If it's a boot device issue it shouldn't loop at all. Clearing CMOS should help but if you can load the bios to begin with, I'd simply suggest loading optimized defaults from there. Was this a new build? Can you provide more background to this issue?
Blue screens eh? Did you try setting it to Wumbo?
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165018
Yeah I can go into the bios settings but I don't know what to do lol
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165022
1. New pc?
2. Working fine, then suddenly this problem occurred out of the blue?
3. Did you introduce new parts?
This is what happend I was resetting my pc to factory defaults and then it said the reset couldn't be done so I had to cancel it then it reset my pc and that's when it started happening
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165180
Were you resetting within the operating system level? It's likely the OS tried to fix something in the EFI partition and messed up when you cancelled half way. It's an uncommon error, but has happened to me before.
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165212
Idk maybe so what do I do now?
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165238
Well, if you have the windows install disk you can boot into the install disk. Inside there is a repair boot loader option that may be able to resolve this issue. If it fails, remove your drive, get a new spare drive, reinstall windows there, boot into new installation and connect old drive so you can migrate your old stuff over.
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165260
Why do I have to get a new hard drive I don't want to pay for another one
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165275
Well you don't have to, that's only if suggestion 1 fails and the installer disk can't fix the issue. Otherwise, it's kinda hard to say if it's a mobo issue or the boot loader that's having issues.
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165296
if you dont want to do that then reinstall windows on the hhd you have but you will loose all your data etc
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165305
I don't understand though why would my hard drive just stop working lol
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165306
It didn't stop working, you simply corrupted to EFI data on it by cancelling the reset. It's not your fault, more like a series of unfortunate turn outs, but the drive is likely 100% working if it's not making clacking noise.
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165314
So how do I fix this then?
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165336
4 minutes ago, Damocles said:
Installer disk for windows. Select the drive, and right before you install, there is an option to repair the boot loader. This will fix it or at least should as it was meant for this type of problem.
I don't have an installer disk windows 10 is on my hard drive lol
https://linustechtips.com/topic/632449-pc-problems/#findComment-8165361
