The build looks good for a budget pc to me. However, if your budget is really tight, you may wanna hold off on getting 3 extra fans since your case already has 2. Adding 3 more fans on top of that won't make a big difference in temps and you could use that money for other upgrades (like your future ssd)
At most, I would only add 1 extra fan to that case for now (on a tight budget, otherwise make it rain fans if that's your cup of tea)
When in doubt, re-format.
https://linustechtips.com/topic/632316-first-project/#findComment-8163379
2 in front 1 on the bottom 1 on the back and 1 on the top are the fans.
https://linustechtips.com/topic/632316-first-project/#findComment-8163394
I'd go used here as you can get some really good parts for really cheap. Other wise try getting a Z series board, A better PSU with more wattage around the 650w range, two sticks of ram instead of one for dual channel, and a RX480 or a 1060.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
https://linustechtips.com/topic/632316-first-project/#findComment-8163403
Just now, Cynestal said:
Is that good airflow?
You don't need fans everywhere. The one bottom wont provide that good of airflow either. The case also comes with fans.
https://linustechtips.com/topic/632316-first-project/#findComment-8163414
1 minute ago, Cynestal said:
so maybe buy the coolermaster led fan and put it in the front?
LED fans are generally not as good as just normal fans but I guess.
https://linustechtips.com/topic/632316-first-project/#findComment-8163433
the case comes with a coolermaster LED fan on the front and a non-led fan for the rear. What we are saying is don't buy any extra fans for now since the 2 that come with it should be enough.
Also, don't get a z series motherboard as someone above said since you will not be getting a K processor.
https://linustechtips.com/topic/632316-first-project/#findComment-8163434
Its a corsair case. Not coolermaster so it has a corsair LED fan.
And he should get a Z series mobo for if he wants to upgrade in the future. I also think skylake Z series can blck overclock so even a non K would get some benefit. I still say he should buy used here. 3770k + a Mobo will go for the same amount.
https://linustechtips.com/topic/632316-first-project/#findComment-8163449
So the build is good tho right? It wont overheat or anything?
https://linustechtips.com/topic/632316-first-project/#findComment-8163457
No the build wont overheat. It's just got a bad GPU as at that price you could get a RX480 or a 1060 or even a 970. You have haswell chips and a mobo with no overclocking potential. The PSU could have a little more wattage and you only have one stick of ram and not two so you loose dual channel support.
https://linustechtips.com/topic/632316-first-project/#findComment-8163469
The gpu is the best for the 200 euro price range in my country, and i wont be doing overclocking
https://linustechtips.com/topic/632316-first-project/#findComment-8163483
Then why are you using the american site. You even said that it was in dollars.
https://linustechtips.com/topic/632316-first-project/#findComment-8163489
Whatever, its an LED fan, my point stands regardless of brand.
As far as buying a z motherboard....it makes absolutely no economical sense to buy a z motherboard with plans on upgrading the cpu in the future since the cost up "upgrading" will be the full price of a k CPU. If he wants to go with a K cpu, he should do that from the get go, unless he opts for like a $40 cpu to start, not an i5 already.
https://linustechtips.com/topic/632316-first-project/#findComment-8163502
Its $95 for an Asus z series motherboard. Not a huge jump in price at all. And the difference between a low end i5 and an unlocked one is over $50. You could also upgrade to a used i7 K series later for cheaper than new now.
https://linustechtips.com/topic/632316-first-project/#findComment-8163513
moved to new build planning
https://linustechtips.com/topic/632316-first-project/#findComment-8163576
