compatibility Test? help me
Go to solution Solved by ShadowCaptain,
7 minutes ago, JigneshDubariya said:
There are some things i need in my pc
1. AIO Cooler
2. Geforce GPU
3. Intel CPU
4. cooler master maker 5
1) why? air coolers are just as efficient as an AIO and more reliable
2) why? the 1060 would be a good option but no prices on there yet, - you could get a 970 for the price of the 480 I put in
3) it is intel
4) why? its expensive and unnecessary in a budget build
You have a limited budget, buying pointlessly expensive cases and coolers will not make your PC better
Do not buy that kingston SSD -
Do no buy a WD purple - they are designed for surveillance systems, blue and blacks are for normal PCs (and greens but they dont exist anymore)
honestly this PC is just all wrong, why are you getting such a shit GPU but buying such an expensive case?????
What is your actual budget, you can do MUCH better
14 minutes ago, JigneshDubariya said:
For pc my budget is 1100$
and other accessories (keyboard, mouse ,speaker, Cable management ) etc -  250 dollars
Something like this is a better option
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($204.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard  ($65.38 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($66.99 @ Newegg)
Storage: Crucial BX200 240GB 2.5" Solid State Drive  ($64.99 @ Adorama)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: Sapphire Radeon RX 480 8GB Video Card  ($269.99 @ B&H)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($77.99 @ SuperBiiz)
Monitor: Acer G257HU smidpx 25.0" 60Hz Monitor  ($269.99 @ B&H)
Total: $1151.69
Generated by PCPartPicker 2016-07-25 05:10 EDT-0400
1. AIO Cooler
2. Geforce GPU
3. Intel CPU
3) it is intel
