Budget of around $50 usd max, Im on a crazy budget trying to upgrade my pc. Atm have a very old thermaltake matrix which ive modded to fit 240mm rad. Looking for somthing slightly more stylish which supports 240mm or easily modded to, which also has atleast 1 hhd and 1 ssd bay. Cheaper the better.
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/632001-cheapest-240mm-rad-case/
Whats your form factor? For that price and mATX the best option is the 88r from corsair imo.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/632001-cheapest-240mm-rad-case/#findComment-8159967
Yes mATX
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/632001-cheapest-240mm-rad-case/#findComment-8160027
There one on trademe for $1 lol bo reserve might try grab it. http://www.trademe.co.nz/Browse/Listing.aspx?id=1128778336
Anyone have any other suggestions?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/632001-cheapest-240mm-rad-case/#findComment-8160111
