Hi guys,
So I will start going to university this September but I need a loptop to make my studies easier. My main job will be programming, coding and etc. Maybe light photoshop, maybe light 3d work. I am guessing that I will code with visual studio or Unity. So I need a laptop that could power this up with no problem and would make my job easier to deal with. At home I have quite decent computer, so the laptop will be used during the day.
For now I am looking into Dell xps 13 2015, but I am starting to get doubts about the size of the screen and the CPU and RAM power. Will i5, 13inch screen and 8gb of ram will be enough? Please share your opinion and suggestions.
My budget is about 1500 eur.
https://linustechtips.com/topic/631878-first-laptop-help/
have you considered buying a cheaper laptop and then also buying a desktop? because that might be a realy good option
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/631878-first-laptop-help/#findComment-8158438
5 minutes ago, iFishas said:
Hi guys,
An i5 could work, depending on which i5. The screen size is mostly personal preference but I think 13in is a bit small for graphic design. 8gb RAM might be pushing it, though, for graphic design.
The ASUS ROG GL752VW-DH74 might be a good option, though marketed towards gamers. it has a 6700HQ and 16GB RAM, along with a 960M
https://linustechtips.com/topic/631878-first-laptop-help/#findComment-8158454
Thanks for you suggestion. I will look check that Asus laptop
https://linustechtips.com/topic/631878-first-laptop-help/#findComment-8158492
https://linustechtips.com/topic/631878-first-laptop-help/#findComment-8158496
4 minutes ago, 21rkosta said:
Yeah.. It looks to me like a big junk to carry around. I would like to go with a laptop which is more like ultrabook style, light, fast, stylish.
https://linustechtips.com/topic/631878-first-laptop-help/#findComment-8158526
