Hi!
This is some sort of continuation from this thread that I created a while ago. The forum suggested that I shouldn't continue posting there because it's "quite old".
Anyways, I am almost done planning my new build, which is as follows:
New Build
CPU: i7-6700k
GPU: GTX 1080
RAM: G.Skill DIMM 16 GB DDR4-3200 (2x8GB)
SSD: Samsung 950 Pro
WiFi: TP-LINK TL-WDN4800
Motherboard: ASUS MAXIMUS VIII HERO
Case: Corsair 750D Airflow
PSU: be quiet! Dark Power Pro P11 650W
I settled for an air-cooled build, mostly using Noctua fans.
CPU cooling: Noctua NH-D15
GPU cooling: Arctic Accelero Xtreme IV
I have a question regarding the Arctic Accelero Xtreme. Which 1080 should I pick? Should I just get the cheapest 1080 (which would be the Palit GeForce GTX 1080 Jetstream for €729) since I'm going to replace the stock cooling anyway?
Now I have another question regarding the placement of the case fans. Would this placement make sense?:
And what do I have to implement or which software do I have to install to be able to control these fan speeds separately:
- CPU fans
- GPU fans
- Case fans
I am looking forward to your replies! :D
https://linustechtips.com/topic/631801-cooling-solution-for-a-new-build/
10 minutes ago, Wario said:
Hi!
New Build
CPU: i7-6700k
GPU: GTX 1080
- CPU fans
- GPU fans
- Case fans
that all looks fine and you might need a PWM fan control hub
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
