Multi-Monitor Problem in CSGO
Solved by elpiop,
There are no ini tweaks that will make it work. You could do something like this, so that the only way you'll move your cursor onto the other screen is if you go to the top corners. Though the post above about Dual Monitor Tools is a more fool-proof solution.
Featured Topics
GOATWD ·
Posted in Operating Systems0 -
Wubb ·
Posted in New Builds and Planning2 -
erico2304 ·
Posted in Troubleshooting1 -
aisle9 ·
Posted in Peripherals1 -
5
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
2
