wd-40-smart-straw-voc-12oz_straw_up_righ
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/631734-case-window-scratched/#findComment-8156941
3 hours ago, MerpDerpHerp said:
So my case's acrylic window got scratched and I was wondering if there is any way how to remove the scratch the cheapest way possible (I tried toothpaste but it didn't work too well).
The case is a SPEC-01 from corsair.
Thanks!
The Novus polish kit is your best option in terms of removing scratches:
https://www.amazon.com/NOVUS-7100-Plastic-Polish-Kit/dp/B002UCYRZU
-Moved to Modding Section-
https://linustechtips.com/topic/631734-case-window-scratched/#findComment-8157742
