I'm currently using an FX-4350, not stock cooling but I can't remember, something Cooler Master I think. It's incredibly loud, even on idle. I've been wondering what air cooler to use as there are a ton of options. I'm mostly focused on being as quiet as possible and I don't want to deal with water cooling.
Any suggestions? Thanks.
https://linustechtips.com/topic/631495-recommended-cooler/
I have a Hyper T2 in one of my systems and it stays decently quiet.
https://linustechtips.com/topic/631495-recommended-cooler/#findComment-8154102
47 minutes ago, Tux The Penguin said:
Good aesthetic and know as the Hyper 212 EVO killer
For slightly better performance at roughly twice the cost. It's major selling point is that it's 15mm shorter than the evo. I'm not a particular fan of the evo, though I've come to accept it's performance/price, but I wouldn't classify the h7 as it's killer.
If you're spending that much and you have the room in  your case you might as well buy a noctua nh-u14, roughly the same improvement over the h7 as the h7 over the evo, and only $10 more
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/631495-recommended-cooler/#findComment-8154315
Have you tried lowering fan speeds?
Can you find out the model name of your cooler?
https://linustechtips.com/topic/631495-recommended-cooler/#findComment-8157576
