Catastrophic Malfunction Help
Go to solution Solved by don_svetlio,
Either that or the board got damaged.
So i was trying to clean up the wires in my PC, and i also decided to put in a cleaner looking SATA cable, it had 3 SATA power connectors, so i 2 of them to my SSD, and HDD. When i turned the PC on, the whole thing engulfed in smoke. When i investigated what happened after shutting down the PC, i found the SSD like this (see pic). Obviously, the SSD is a complete loss, but the rest of the PC is fine, and connectors on the HDD seem to be intact. However, it's not showing up in the Bios. Basically, what I'm trying ask, is the HDD also fried? Thanks in advance for the help.
CPUIntel Core i5 6600k 4.4GHz Motherboard: Asus Maximus VIII Hero RAM: Corsair Vengeance LED 16GB DDR4  GPU: Asus STRIX GTX 1080 Case: Thermaltake Core P3 SE White Storage: Toshiba P300 3TB HDD, Samsung 850 PRO 128GB SSD PSUCorsair RM750i Displays: Asus VG248QE, Asus VX22H x2 Cooling: Corsair H100i V2 w/ HD120 x2 KeyboardCorsair K95 RGB PLATINUM Cherry MX Brown Mouse: Corsair Dark Core RGB, Corsair MM800 RGB POLARIS Mousepad Sound: Corsair VOID Wireless, Logitech Z323 Speakers OS: Windows 10
https://linustechtips.com/topic/630377-catastrophic-malfunction-help/
The drives are dead. I remembered i have an optical drive, and all 6 of my SATA ports reconized it. Thank you for not being sarcastic about the situation.
Just now, Solegide said:
The drives are dead. I remembered i have an optical drive stored away, i tested it in all the SATA ports, and all 6 of them reconized it. Thank you for not being sarcastic about the situation
