What is the best ITX case?
So I am going to build an ITX build as I'm moving back to university and need something smaller.  So the LTT community I need your help!
What do you guys think is the best and what have you built in yourself?
I was thinking something like the Thermaltake Core V1
https://linustechtips.com/topic/630365-best-itx-case/
How do you define best? It depends on what you're after in a case. Smallest size? Room for a certain cooler or GPU?
I went with a Silverstone SG13 as one of the smallest size ones, but it is tight in there and limited in GPU space.
https://linustechtips.com/topic/630365-best-itx-case/#findComment-8140806
I recently built in the Fractal Node 202 and it was so well designed I managed to fit a complete CPU/GPU custom water cooled hard loop in it as well.
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
https://linustechtips.com/topic/630365-best-itx-case/#findComment-8140824
For me it would be something that allows me to build a good system in while still being portable. I don't want a console killer style case, just something small and easy to work with.
https://linustechtips.com/topic/630365-best-itx-case/#findComment-8140827
What is it like in terms of PSU? It seems like you need a slim one? Also is the clearance good for CPU coolers?
https://linustechtips.com/topic/630365-best-itx-case/#findComment-8140856
You need an SFX PSU (although they sell a version of the case both with and without a PSU). CPU cooler clearance is for stock coolers or low profile only. You can also only fit SSDs in there without some non-standard messing around.
https://linustechtips.com/topic/630365-best-itx-case/#findComment-8140916
