Trying to set up Folder Redirection But the GPO won't apply. I have tried running Gpupdate /force and performing a reboot, I did not get the thingy where I have to type Y.
Here is the GP Result from the client machine
The OU containing the Group and User account, the user account is a member of the Group.
The Group scope of the group is: Global
The Group Type is: Security
GPO Scope:
It is worth mentioning that the GPO is enabled under details
And the GPO is linked to Test OU Where the user account and group is.
Folder Redirection of Documents folder
Share Users
Share permission for Test Group
if there are more information required please ask, I will reply asap.
I have managed to do this exact (I think) configuration on a few VM's running on viritualbox, when comparing the configuration against what I'm doing now I can't seem to find a difference, I might have missed something though.
System
CPU: Intel Core i7 5820K @4.5GHz - 1.230v  RAM: HyperX Fury DDR4 4x4GB 2666MHz  MB: MSI X99S SLI PLUS  CASE: NZXT H440  CPU-COOLER: Fractal Design Kelvin S24  PSU: Corsair RM1000W w/ white sleeved cable kit  GPU: MSI GeForce RTX 2070 ARMOR  MONITOR: LG 27GL850-B  STORAGE: Samsung 970 EVO 1TB M.2, Samsung 840 EVO 256GB,  WD Red 3TB
https://linustechtips.com/topic/630343-gpo-not-applying/
'gpupdate /force /sync /boot' is what I use to really make sure group policies update. The /boot switch required an acknowledgement.
Here is the Microsoft permissions requirements for folder redirection, https://msdn.microsoft.com/en-us/library/cc736916(v=ws.10).aspx?f=255&MSPPError=-2147217396. Remember to take note of both the share permissions and the NTFS file system permissions.
Also it is easier to look at applied GPO setting on a client by using gpresult /h C:\gpresult.htm
https://linustechtips.com/topic/630343-gpo-not-applying/#findComment-8141933
