ok so i have overclocked my gpu's but this time less than before and every time i start up a game the gpu fan speeds up to 70% and the game go's ape S**t then after that the pc runs but cant do anything as the second i do somthing the screen go's blank and staysd like that till i reset the pc
post-18784-0-45152800-1381079425_thumb.j
I did a thing once and it was awsome: https://soundcloud.com/jamese666/junkhead-cover-with-vocals
https://linustechtips.com/topic/63023-gpu-problems/
Try using MSI afterburner to mess around with the fan speeds.
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/63023-gpu-problems/#findComment-861257
i have my fan curve set on presision x
Try removing it from there and trying it on MSI afterburner. It might be causing some problems.
https://linustechtips.com/topic/63023-gpu-problems/#findComment-861268
Try unchecking the auto option and click on fan curve to reset it? I would get MSI Afterburner OSD display to see if there was a spike in temps that caused this to happen.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/63023-gpu-problems/#findComment-861278
the fans aint what im worried about it the whole game crashing and having to restart my pc for me to use it and the fact that the ovverclock is less than my usual
https://linustechtips.com/topic/63023-gpu-problems/#findComment-861321
Never go over 50 on core clock, it will most def. crash the driver, it won't help that much anyway, soooo.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/63023-gpu-problems/#findComment-861340
well like i said i've had overclock more than that so it's just strange
https://linustechtips.com/topic/63023-gpu-problems/#findComment-861367
Dem drivers man, can't compete with them, as i said, not much of an improvement, so drop it until it stops crashing. 70 on the mem should be fine, i roll with that.
https://linustechtips.com/topic/63023-gpu-problems/#findComment-861664
