I want to get a new video card to play Overwatch
But I am not sure what is the model of my PC case so i dont know how to open it correctly without damaging anything
i am also not sure if my gpu is embedded with anything else
any suggested actions i shud do?
https://linustechtips.com/topic/630221-help-needed/
Take the side panel off, make sure your power supply has all the supplemental plugs for an RX480, and carefully slide the GPU into the highest PCI expansion slot the layout of your parts in your chassis will allow. Plug in the cables from your power supply and you should be good to go.
https://linustechtips.com/topic/630221-help-needed/#findComment-8139699
