I put this thing together without care for the looks. I now have the options to make this have a color them, or just some tidying up. I am going to expand ram to 16GB, so i could get a certain color or paint them. Right now i have Mushkin Enhanced, Greyish cooler ram. I can't decide if i should do more white or red. Also i don't know if i should do anything with all the case plug-ins in the bottom, they kinda stick out and I dont like it. I will take out the board speaker, it doesn't do anything. I went with a case with a plain front because it fits well with the entertainment system.
Computer Specs:
MOBO: MSI z97 Gaming 5
CPU: Intel i5 4460(may upgrade also, do i need to?)
Cooler: Cryorig H7 Tower
Ram: 2x 4GB Mushkin Enhanced 1333
GPU: ASUS Strix GTX 1070
Storage: 120 GB ADATA SSD, and other HDDs
Case: DIY-PC Silence-BK-Window(Yeah it's Cheap but doesn't look bad and lots of features.)
Photo dump...
IMG_20160719_215139.jpgIMG_20160719_215147.jpgIMG_20160719_215221.jpgIMG_20160719_215127.jpg
https://linustechtips.com/topic/629398-aesthetic-advice/
Wipe down and clean up that side panel! YIKES
        MY RIG
Intel core i5-6600k | Hyper 212 EVO | Gigabyte Z170-HD3 | G.SKILL Ripjaws V Series 16GB (2X8) | Samsungs 850 EV0 250GB | WD BLUE 1TB | Gigabyte Geforce GTX 1070 G1 | Corsair 200r | EVGA SuperNOVA NEX 750W 80+ Gold
https://linustechtips.com/topic/629398-aesthetic-advice/#findComment-8133005
