Would rubber washers work
Solved by TrueMegaManiac,
Just now, Bajantechnician said:wait what i dont understand your sentence and the lack of periods or large letter case makes it even harder
I think his question is more or less does he need rubber washers on his screws for mounting the motherboard, and the answer is washers at all aren't really needed in my experience. Just get screws that are properly threaded.
