3 minutes ago, roy12 said:
i saw a video on liquid cooling and they put fans on the radiator do i have to buy fans and do that?
Yes the fans are to pass air through the fins so the heat from the fluid and rad can be transfer to the air for cooling, however there are such things as passive rads which do work but are much larger and bulkier as they rely only on convection and ambient air movement.
https://linustechtips.com/topic/629286-liquid-cooling/#findComment-8128140
yes.
heat has to be dissipated somewhere. all liquid cooling does is move the heat away from the CPU faster, and to the radiator, where it still needs to be cooled like a normal heatsink
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/629286-liquid-cooling/#findComment-8128144
Just now, roy12 said:
im planning on buying Corsair Hydro Series H100i GTX Extreme Performance Water / Liquid CPU Cooler. 240mm
Yes that unit comes with the fans in the box:
http://www.legitreviews.com/corsair-h100i-gtx-extreme-performance-liquid-cpu-cooler-review_160695/2
https://linustechtips.com/topic/629286-liquid-cooling/#findComment-8128174
