Just now, SageOfSpice said:
Put together a theoretical build for another user a bit ago, fits the criteria.
http://pcpartpicker.com/list/wTTKBP
It looks good, except that you don't need a 750 watt psu, and you could get a 500 watt. Also, I would recommend a 1 tb hard drive which is around $40. http://pcpartpicker.com/list/kbm9JV
https://linustechtips.com/topic/629215-friend-needs-help/#findComment-8127155
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($179.89 @ OutletPC)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($49.99 @ Amazon)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2133 Memory  ($30.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: XFX Radeon R9 380X 4GB DD XXX OC Video Card  ($179.99 @ Newegg)
Case: Cougar Spike MicroATX Mini Tower Case  ($30.98 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($59.86 @ Amazon)
Total: $579.18
Generated by PCPartPicker 2016-07-19 18:31 EDT-0400
https://linustechtips.com/topic/629215-friend-needs-help/#findComment-8127529
