Hi.
I just built my Skylake i3-6100 PC and I did some very very light blck overclocking on it (3.8ghz with stock cooler, crucial 2133mhz DDR4 to 2600mhz). It passed all the stability tests (Prime95, Intelburn, Memtest) and  the core temp never exceeded 82C (hovering around 75C). However yesterday, while I was streaming video, the screen suddenly went black and I needed to force my PC to reboot. It happened again today and I don't know what's the problem.
Does anyone has any idea what happened? Thanks in advance for your help.
https://linustechtips.com/topic/629046-computer-stability-problem/
Are you sure the screen went black because of the CPU? It could be the GPU's fault
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
Stress testing will not ALWAYS make instabilities show. Sometimes tasks such as opening a specific program that isn't CPU intensive can trigger a crash. Its kinda a crapshoot. Try toning down the OC and see if you still have the issues.
When in doubt, re-format.
Try using Adia 64 to stress all parts of the system
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
Just now, zongyf said:
Can it be the monitor's fault. I'm using the VGA cable that comes with it.
Try using a full system stress test eg Adia 64
If it happens again back of the overclock
When the RAM & CPU is overclocked via FSB on the 2011_V3 socket I know you have to play with the CPU_VTT voltage which (correct me if I'm wrong) is the voltage that goes in between the CPU and the RAM. increasing that gradually might help. Also loosening the timing on the RAM and maybe bumping up the RAM 0.5V could help. Alternatively you could reset the RAM to 2133MHz and run it at factory. Then keep the CPU OC.
Doing it now. But when do I stop the test?
Depends on how long you want to
If it doesn't crash with in the first 40mins 1hr then odds are it wont
Is that OK if I set the voltage to auto so the system do it itself?
Don't use AUTO, AUTO is default voltage.
9 minutes ago, zongyf said:
Is 1.2 Vcore OK then? I did some really small overclock.
You're on the Z170 chipset, I'm on X99, I cannot verify what a proper OC voltage is for your processor. All I can do is tell you what voltages to play with.
