Best Intel CPU for 1060?
Go to solution Solved by GarnetDevil,
I'd get the Xeon 1230V5 (although i5 6500 isn't all bad)
whatever fits your needs, a 6500 or a 6600/k is good
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/629037-best-intel-cpu-for-1060/#findComment-8124656
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
https://linustechtips.com/topic/629037-best-intel-cpu-for-1060/#findComment-8124673
Just now, Mother said:
You sure? Aren't Xeon's those strong-ass cpu's?
E3s are basically underclocked i7s without onboard GPU, they are $40 cheaper than 6700 and nearly $90 cheaper than 6700K
They aren't as P/P as the 1231V3 (Haswell Refresh) but hey, pair it with the Asrock E3V5 OC board and you can OC it, overall it's not a bad choice
#Gadget:
https://linustechtips.com/topic/629037-best-intel-cpu-for-1060/#findComment-8124695
Oh, ok.
https://linustechtips.com/topic/629037-best-intel-cpu-for-1060/#findComment-8124701
Xeons are server cpu's. They generally aren't as good at gaming on the higerr ends as a good i5 or i7 since they tend to have more cores but at a lower speed. The specific xeon mentioned is a really well priced one that competes with the i7 which is a lot more expensive (minus being able to OC)
When in doubt, re-format.
https://linustechtips.com/topic/629037-best-intel-cpu-for-1060/#findComment-8124703
