Ethernet Cable length and performance
Cat5e and Cat6 are certified to handle specific speeds. Cat5e can handle 100Mbits up to 100 meters, and Cat6 can handle 1Gbit up to 100 meters, with no signal loss. But, Cat5e is pretty good also at handling Gb connections for most runs... For home use, Cat5e is fine even at Gb as you never really stress it...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
Cat5e and Cat6 are certified to handle specific speeds. Cat5e can handle 100Mbits up to 100 meters' date=' and Cat6 can handle 1Gbit up to 100 meters, with no signal loss. But, Cat5e is pretty good also at handling Gb connections for most runs... For home use, Cat5e is fine even at Gb as you never really stress it...[/quote']
Thanks im going to go with cat 5 then
