what's going on I just finished building my pc and was wondering if im lacking something or somewhere I mainly built it for gaming and streaming but might use my old rig strictly for a streaming one I play arma 3 which I know is super cpu intensive and im getting anywhere from 30 to 50ish fps which is way better then my old set up which was 10 to 20fps I would like to try and get a avg of 60 fps if not more but I need some help my setup is
i7 6700k
msi z170a xpower gaming titanium addition
gskill 16g 3000
evga gtx 970 ssc
now I have used the overclocking feature in the msi bios and oc the cpu to 4.59mhz and the gskill to 3060 now im new to oc so I was going based off of the help menu but with that being said I need some help getting the most performance out of my rig thanks
https://linustechtips.com/topic/628349-possible-performance-issue/
1. Since you're overclocking make sure there's enough airflow in your pc. A hot Rig is a dead Rig.
2. try and bump down the settings in Arma. I know you want to run it at max settings and all, but if you end up having glorious graphics and 2 fps, it's probably time to crank those settings down a notch.
3. If you're having a problem streaming try to upgrade your internet speed or connect your pc directly using a LAN cable. It works wonders, easily doubled my web speed.
In the end your pc sounds like quite a beast, just note that Arma 3 is one of the most demanding games on the market currently, so streaming it on a non-godlike machine on max settings is probably going to be difficult.
Best of luck!
