(?) Best within budget wireless router/wired router/Isp phone router/modem
Kyzer
I want a around $100 router/modem (means i want one that does both) that has at least 3 out rj45 gigabits, 1 phone connector (isp), and has wireless. Wireless has to be good and has little interference with walls and works in a big house, needs to be able to handle metal objects nearby. I would also like MAC address self changing support so i can change my public ip if need be. I plan on running servers so i cant have ddosing scrubs.
If a router like this is a bit too expensive (say, $200+), do you have any suggestions for something i can build?  I know you can make pc's into modems and routers.
USD.
But first, let's talk about parallel universes.
Intel i7-4790k undervolt, NVidia EVGA GTX 980Ti SC Reference, NVidia EVGA GTX 480 SC Reference, ASUS Z97-A/USB3.1, SK Hynix SL308 240GB, WD Green 2TB, Hynix 1333 8GB (4x2), XFX Core Pro 850w, NH-U12S, 4x NF-F12's, Sennheiser HD 558's, Blue Yeti, Corsair K70 (red), Logitech MX Master, XBox One Controller, ASUS VG248QE 144Hz, HP 2010i
bump-jabroni
