Hi,
So I am entering the PC-MasterRace and I have some knowledge of computers 'n stuff.
I want to build a pc with upgradeability in mind.
Will this work:
Case: NZXT Noctis
PSU: Corsair CS550M
CPU: Intel Core i5 6500 with stock cooler (planning on other cooler ofc but I'm not overclocking the cpu)
MOB: MSI H170 Gaming M3
RAM: HyperX Fury 2133MHZ 8GB (planning to add a second stick in the future for 16GB total)
SSD: Some old OZC 60GB that I have, also needs an upgrade.
HDD: Same story as the SSD
GPU: TBD (probably RX480 or 1060)
I'm happy with any response, criticism or ideas.
Regards,
Snieky
https://linustechtips.com/topic/627945-building-my-first-pc/
If you want room for upgrades you'll definitely need another PSU. I'd probably recommend the corsair RM750x, since it comes with a 7/10 year warranty. More than twice that of the other ones, for a little higher price, and the wattage will come good when you're adding your second GPU.
60gb SSD will be a pain to use as a main disk, since Windows will take up a third of it before you're even at the desk, and a fifth would be good to keep empty to make it easy for the old guy to keep up with demands. So you'd be left with barely 30gb to use, so you should probably get yourself a decent HDD and use 50gb of the SSD as a cache through Intel's Rapid Storage Technologies, which will look out for the disk for you. (mostly)
Excuse my broken keyboard
CPU - Ryzen 7 2700x
GPU - RX Vega 64
SSD - Samsung 970 M.2 500GB
HDD - WD Black 4TB
Mobo - Asus ROG Strix X470-F Gaming
RAM - 32GB Corsair Vengeance DDR4
PSU - Corsair RM1000x
https://linustechtips.com/topic/627945-building-my-first-pc/#findComment-8099506
35 minutes ago, Snieky said:
Hi,
Will this work:
Case: NZXT Noctis
PSU: Corsair CS550M
Regards,
Snieky
It looks good. If you ever want to get a overclockqble cpu a 600-700W psu would be better. All around balenced build. Gj
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/627945-building-my-first-pc/#findComment-8099584
1. Get the corsair 400c case IMO it looks better and it offers better air flow.
2. Oh god no not the CS. Get the EVGA supernova g2 650w or 550w it's the same price as the corsair and MUCH better.
3. Try and get higher speed ram, the faster the better even for i5's
4. continuing from my 3rd point: Get a Z170 board here's one that's the same price as the gaming m3: asRock fatal1ty gaming k4. It has potential for more than 2133MHz ram and better future expand ability.
other than that it's a great pc. Make sure to do your research, the more the better.
XTREME I7 GRANDIS TRIDENT SUPERNOVA ECLIPSE PC++:
CPU           ✧   i7 6700K  @ 4.5 GHz 1.31 VCore
COOLER   ✧   SilentiumPC Grandis
MOBO       ✧   MSI Z170A GAMING PRO CARBON
RAM          ✧   16Gb Trident Z's 3200 MHz
GPU          ✧    Gigabyte GTX 980 ti XTREME
SSD           ✧   Samsung 850 Evo 250 GB
PSU           ✧   EVGA SuperNova G2 650W
CASE         ✧   Phanteks Eclipse P400S [Black]
Use:
✧ Game designing, Programming, Compiling, 3D rendering and of course Gaming
https://linustechtips.com/topic/627945-building-my-first-pc/#findComment-8100961
A Z170 motherboard on a nonK CPU is a bit waste. Like I said before, for whoever goes H170 a good option is the H170 Hyper series, that model allows overclocking for nonK CPUs :)
https://linustechtips.com/topic/627945-building-my-first-pc/#findComment-8101102
Not really - as I said it offer more ram frequencies and future expand ability for the same price ... totally worth it.
Use:
https://linustechtips.com/topic/627945-building-my-first-pc/#findComment-8101294
