My first build, i was fine on my asus n550jv for my younger years but i need an upgrade. I created this build from some research and at a price range of around $2000 AUD (including the case and monitor). I have very limited knowledge when it comes to builds so i'm all ears.
Case: Phanteks Enthoo Evolv ATX Mid Tower Chassis Satin Black
Monitor: BenQ RL2455HM 24in LED Gaming Monitor
Mother Board: MSI B150 Gaming M3 Motherboard
Ram: Corsair Vengeance LPX 16GB (2x8GB) DDR4 Red 2133mhz
Storage: Western Digital WD Blue 1TB 7200rpm & Samsung 750 EVO 250GB SSD
GPU: Gigabyte GeForce GTX 980 OC 4GB
CPU: Intel Core i5 6600K + Cryorig H7 CPU Cooler
PSU: Coolermaster GX 550W CM Storm Edition
Some info and questions:
I'll be using it to run games like dayz, gta 5, csgo, arma and ark, as well as using most of the adobe suite with school, music production and unity 3d.
With that in mind:
- what have i done wrong?
- what am i missing or need?
- Is this setup suitable to run 1440p or should i stay at 1080?
- is i7 worth the upgrade?
- Is the Cpu cooler worth it?
- Anything else that is helpful
Thank you and anything constructive is appreciated :)
https://linustechtips.com/topic/627875-build-plan-suggestions/
Why not wait for the 1060? Also stick with the i5, it's decent enough for a 980.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/627875-build-plan-suggestions/#findComment-8098609
PCPartPicker part list: http://au.pcpartpicker.com/list/xVzLJV
Price breakdown by merchant: http://au.pcpartpicker.com/list/xVzLJV/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($332.00 @ Centre Com)
CPU Cooler: be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($109.00 @ PCCaseGear)
Motherboard: ASRock Fatal1ty Z170 Gaming K4 ATX LGA1151 Motherboard  ($209.00 @ Mwave Australia)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($103.00 @ IJK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($119.00 @ IJK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($68.00 @ CPL Online)
Case: Phanteks Enthoo EVOLV ATX Mid Tower Case  ($249.00 @ PCCaseGear)
Power Supply: Silverstone Strider Platinum 550W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($155.00 @ Umart)
Monitor: AOC G2460PF 24.0" 144Hz Monitor  ($412.00 @ IJK)
Other: Radeon RX 480 8 GB aftermarket cooler or GTX 1060 ($400.00)
Total: $2156.00
Generated by PCPartPicker 2016-07-17 21:51 AEST+1000
Wait for the 1060 and aftermarket RX 480's. This is a bit over your budget, but if you can't spend the extra get a cheaper case.
https://linustechtips.com/topic/627875-build-plan-suggestions/#findComment-8098642
wuutt...250$ in AUS?!?? wtf....
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/627875-build-plan-suggestions/#findComment-8098648
Total: $2156.00
Definately waiting for the 1060 now that i've seen it, and the case is where i will cut corners if i need to but that price should do-able. Thanks
https://linustechtips.com/topic/627875-build-plan-suggestions/#findComment-8098670
