Help with how many RAM needed
Solved by Skiiwee29,
2 minutes ago, luckyreygabriel said:Thanks for the reply, are referring to rendering times when you said faster results? That's what I am aiming for.
Rendering time which in turn will mean you can theoretically code the video faster. Alot also depends on your CPU choice as well.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
