Need help about speakers recommendation.
Hello, first post here and I'm looking for some insight about 2.1 Speakers setup for my PC.
First, here's my spec:
CPU: Intel 3770  3.4Ghz
GPU: Nvidia 670 2GB (Will upgrade for RX480 or Nvidia 1060 soon)
RAM: 8GB DDR 3 1600Mhz
HHD: Samsung SSD 840 Evo + Seagate 2TB
PSU: OCZ 750w
MOBO: Asus P8H77-I mITX.
Here's the website for the motherboard: Asus P8H77-I
Ok, so here's the deal...
I'm currently using really old speakers setup which need to be changed. I'm using onboard Audio which according to the website is:  VIA 8-Channel High Definition Audio CODEC   which was fine for the setup that I had for now. It has only a few outputs (Line In, Front Speaker, Microphone and also 1x Optical S/PDIF Out)
I'm planning to upgrade my GPU and my Speakers Setup. I was looking at a few models...
Klipsch R-15M (Or R-14M) along with Klipsh R-10SW Subwoofer
Klipsch Promedia 2.1
Logitech Z623
I know the R-15M + Subwoofer is quite a bit more expensive than Promedia/Z623 but I'm wondering if it would be worth it? My PC will be 95% used for Gaming.
And also wondering if my current motherboard with onboard Audio is good enough for any of these sets?
Thanks for the help!
https://linustechtips.com/topic/627708-need-help-about-speakers-recommendation/
Your on board audio probably will do the job just fine, however you can always throw a sound card in later on if you're unhappy with the sound quality
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
The Klipsch and Logitec are basically interchangeable, and thus both pretty awful. However, a lot of people that don't know or care about audio quality find them to not only be good enough, but pretty good.
The Klipsch bookself speakers would be somewhat better, but be aware that you'll need an amplifier or receiver to power them and connect them to your PC or whatever. I'm not a fan of cheapo subwoofers, so I would skip one on the desktop.
Honestly, if I were you with that kind of budget, I would stick with the Micca PB42X or perhaps JBL LSR305.
Don't forget to tune the built in equalizer (if the drivers include one) to fit your ears!
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
