Need help understanding Memtest
It will test all the RAM in the system but its recommended that you only test 1 stick at a time to make it easier to determine the troublesome stick.
you can see the two bars with % signs at the top:
PASS - Once this reaches 100% it has finished 1 set of tests and will loop back to 1% to run the same tests another time, it is reccomended to run a few passes to test for errors.
TEST - This is the % status of the current test in that pass (1 full pass could be 50 tests for example, so it could be 59% done test 1/50 in that pass)
You are looking for any RED text/bars that show a failure. If you have run a few passes and you dont see any red highlighted sections below where its lists your two RAM sticks then you have no errors and your RAM is fine. If you have ANY errors your RAM is faulty.
For example this is what a failure looks like:
Yes you are correct you have finished 1 pass and its 81% into pass 2.
