Hello everyone! I'm doing another build and i need help!
Budget: 1400$ (CAD)
Cpu: Tell me
Gpu: GTX 1080 (tell me wich one to buy)
Power supply: Thermaltake 850 gold (i already have it)
Case: Tell me
Motherboard: Tell me
Memory: Tell me
Ram: Tell me
SSD: Tell me
Hard drive: Tell me
Thank you
https://linustechtips.com/topic/627128-new-pc-build-need-help/
Budget: 1400$ (CAD)
Cpu: Tell me
Case: Tell me
Memory: Tell me
Ram: Tell me
SSD: Tell me
Hard drive: Tell me
Thank you
Are you going to be overclocking or no because it will help me determine the CPU to put into the partlist
https://linustechtips.com/topic/627128-new-pc-build-need-help/#findComment-8090805
Budget: 1400$ (CAD)
Cpu: Tell me
Case: Tell me
Memory: Tell me
Ram: Tell me
SSD: Tell me
Hard drive: Tell me
Thank you
is the 1080 included in the $1400 or no? if not, here you go http://pcpartpicker.com/list/Lb6FtJ
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/627128-new-pc-build-need-help/#findComment-8090838
Here ya go that budget with the 1080 is as tight as a snake but I think I got it and also I have used the White NZXT source 210 Elite case before it's a great case
PCPartPicker part list: http://ca.pcpartpicker.com/list/6WLBbj
Price breakdown by merchant: http://ca.pcpartpicker.com/list/6WLBbj/by_merchant/
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($283.95 @ Vuugo)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard  ($75.98 @ DirectCanada)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($69.99 @ NCIX)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($88.35 @ Vuugo)
Video Card: Asus GeForce GTX 1080 8GB Video Card  ($807.99 @ NCIX)
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case  ($69.50 @ Vuugo)
Power Supply: Thermaltake EVO-Blue 850W 80+ Gold Certified Semi-Modular ATX Power Supply
Total: $1395.76
Generated by PCPartPicker 2016-07-15 18:53 EDT-0400
also you can buy Windows for cheap here (I have used the keys from there before and they work fine):
Windows 10: https://www.kinguin.net/catalogsearch/result/index/?q=windows+10
Windows 7: https://www.kinguin.net/catalogsearch/result/index/?q=windows+7
https://linustechtips.com/topic/627128-new-pc-build-need-help/#findComment-8090947
Total: $1395.76
Thank you!
https://linustechtips.com/topic/627128-new-pc-build-need-help/#findComment-8090961
2 minutes ago, Fourmi Kill3r said:
Thank you!
also if you want to see a build with that NZXT case just look at my Arctic Wolf build in my signature
https://linustechtips.com/topic/627128-new-pc-build-need-help/#findComment-8090970
Also if you want a inexpensive but very good CPU cooler I don't know where you can find this in cannada but I used it in my Arctic Wolf build and it keeps the 95 watt AMD chip I have in that build nice and cool: http://www.microcenter.com/product/442926/Titan_Universal_CPU_Cooler
https://linustechtips.com/topic/627128-new-pc-build-need-help/#findComment-8091013
Im Thinking http://pcpartpicker.com/list/pBRbXH
Even Though it may be over by $100 dollars, The Total system wattage is a lot lower than the psu you want to use (unless if you already have the psu than you can easily hit $1400)
And this is probably the most proportionate PC list I could make due to price.
https://linustechtips.com/topic/627128-new-pc-build-need-help/#findComment-8091064
19 minutes ago, lee32uk said:
Spending well over half of the budget on the gpu means you are having to sacrifice in other areas. I would go with a GTX 1070 and get a better cpu, case, motherboard etc.
What monitor do you have by the way ?
Actually, i will transfer the 980ti i have in my signature to that pc and take the 1080 to the signature pc (i know it's weird)
https://linustechtips.com/topic/627128-new-pc-build-need-help/#findComment-8091089
