i7 4770k core problem
Go to solution Solved by ttam,
Try setting the number of processor core in your bios to "all" not just set to optimized settings.
Try this;
Click Start
Type "msconfig" into the search box & click it.
Click the Boot Tab
Click "Advanced Options"
Make sure "Number of processors" is UNCHECKED (nothing should be checked except the 2 grayed boxes for debug & baud)
So i was running Cinebench R15 earlier to get a screenshot for a forum earlier and I noticed it was only running at 2 cores and 4 threads. The processor has never been over clocked. Got a score of 328..? Any reason why its only using 2 out of 4 cores?
Specs: i7 4770k
Asus z87 pro
8 Gigs corsair ram
HX650 Corsair power supply
550ti superclocked 2gb
H100i cooling
R4 case
https://linustechtips.com/topic/62695-i7-4770k-core-problem/
check the bios to ensure all your cores are enabled.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/62695-i7-4770k-core-problem/#findComment-856280
Went into BIOS and loaded optimized defaults. Still running 2 cores. Anything else?
have you got a screen shot of hwmonitor?
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/62695-i7-4770k-core-problem/#findComment-856362
Yeah here it is.
yes it is only showing 2 cores that is strange.
Rig Specs:
https://linustechtips.com/topic/62695-i7-4770k-core-problem/#findComment-856752
Try this;
Click Start
Click the Boot Tab
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/62695-i7-4770k-core-problem/#findComment-857929
Try this;
Click Start
Click the Boot Tab
Was about to suggest this, OP try this yes. I remember reading something like this in the past and 9/10 times it usually fixes things like this.
System Specs:
CPU: Ryzen 7 5800X
GPU: Radeon RX 7900 XT
RAM: 32GB 3600MHz
HDD: 1TB Sabrent NVMe -  WD 1TB Black - WD 2TB Green -  WD 4TB Blue
MB: Gigabyte  B550 Gaming X- RGB Disabled
PSU: Corsair RM850x 80 Plus Gold
Case: BeQuiet! Silent Base 801 Black
Cooler: Noctua NH-DH15
https://linustechtips.com/topic/62695-i7-4770k-core-problem/#findComment-858103
