I am currently selecting parts for a new build. I have chosen a Intel Core i7-6800K 3.4GHz 6-Core Processor. I was wondering if my Corsair H100i would do the job well, or if it would overheat. If you could tell me if the processor will overheat, that will be great! Also, if you could suggest any different water coolers that would do the job as well, but would be cheaper, please comment that too. Thanks!
My parts list is: http://pcpartpicker.com/list/9DjgwV
https://linustechtips.com/topic/626482-will-my-cpu-overheat/
Any AIO liquid cooler will do an exceptional job, in other words your computer will be more than adequately cooked and you will have a lot of headroom for an overclock.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/626482-will-my-cpu-overheat/#findComment-8083823
That cooler should be more than enough to keep that CPU cool as long as you aren't going to be doing crazy overclocking and overvolting on it. It will handle normal overclocking just fine though.
When in doubt, re-format.
https://linustechtips.com/topic/626482-will-my-cpu-overheat/#findComment-8083825
The H100i should be ample cooling at stock and probably a respectable overclock.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/626482-will-my-cpu-overheat/#findComment-8083827
What are you planning on using this pc for though? Cause the H100 will get you a great overclocking on a quad core like the 6700k
https://linustechtips.com/topic/626482-will-my-cpu-overheat/#findComment-8083845
