So everyday somewhere from 10-11am est my internet goes out. Sometimes it cones right back, sometimes i have to just reset the router, and other times it stays out for an hour or two. Once it is back it stays on without a problem until the next day around the same time.
Nothing changes on my end before or after it happens. Same number of devices are on it before and after.
Any ideas?
Ps. Let me know if you need any more info, I've never had yo troubleshoot this before so idk what else to provide.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/626358-daily-connection-loss/
1 minute ago, refinedskillz said:
Contacted your ISP? If its on all devices then its got nothing to do with your PC.
Yeah I will. Never said it was my PC I was wondering if it was hardware on my side like the router.
https://linustechtips.com/topic/626358-daily-connection-loss/#findComment-8082312
I have a similar issue that was happening to me. Turns out I was loosing connection to DNS servers for a little bit. I ended up resetting my router back to factory default and set it back up. Fixed it for me, the only thing I forgot was that I had left my DNS servers as Google's DNS servers which I set back to auto. Has been fine for me since.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/626358-daily-connection-loss/#findComment-8082317
