Im kinda new to pc building i wanted to know if this case was big enough to fit all this. same thing with the HDD slots im terrible with sizing stuff
Here is the link to everything including the case http://pcpartpicker.com/list/yQvvnn                   THX
https://linustechtips.com/topic/626144-need-help-with-case-sizes/
"case sizes" only give you the size of motherboard supported, in this case ATX, which your motherboard fits. The only other concern is fitting other things like your drives and fans which all should be fine. On a side note I wouldn't recommend that case or any by DIYPC, I've had bad experiences with them. Try the NZXT S340 :)
It should.
I would definitely scrap something (like 8GB of RAM) so you could get an SSD in there.
