Hi,
i almost finished planning my first gaming build and would like to ask you for your opinion on this.
CPU:            AMD FX-8350 4.0Ghz 8-Core
Mainboard:  GIGABYTE GA-990X-Gaming SLI
RAM:           Kingston HyperX Fury Red, 8Gb, 1600 Mhz
GPU:           Zotac Geforce GTX 970 4Gb
SSD:            ADATA 128GB Premium Pro SP900
HDD:           Western Digital Blue 1TB WD10EZEX
PSU:           Corsair CP9020076 CS550M 550W 80+ Gold
Case:          Corsair Carbide SPEC-01
In Germany, where i live, this setup would be about 800€ so approx. 887$
I have not decided what CPU Cooler to use, do you have any tips or recommendations? (Should be Air btw)
Will there be any bottlenecks, what would you change?
I thougt adding an "exhaust" Casefan, would it make any difference?
Thank you in advance for your help.
Regards from Germany
Finn
https://linustechtips.com/topic/625730-first-pc-build/
Hi Finn !
There is one thing I wouldn't do if I were you : buying a 970 with all the cool stuff released now (RX 480 / GTX 1060 at the same price point), the 3.5Gb of VRAM is really a reason not to buy one with the more compelling offers appearing right now. I know there is no 1060 yet and not custom RX 480, but you might want to wait and see. Or look around for used 980/390X if you really want something now.
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
https://linustechtips.com/topic/625730-first-pc-build/#findComment-8075390
If you are going with 8350 then get cpu cooler with fan blowing at the mobo aswell to keep parts on mobo cool aswell. Also if your not too fond of amd's cpu then if you have spare cash go with intel cpu's, for better single core perf, lower temps and upgrade path.
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/625730-first-pc-build/#findComment-8075399
i'd go with something like this:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (€207.69 @ Mindfactory)
Motherboard: ASRock H110M-HDV Micro ATX LGA1151 Motherboard  (€56.49 @ Amazon Deutschland)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR4-2400 Memory  (€32.99 @ Amazon Deutschland)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  (€59.99 @ Amazon Deutschland)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (€51.66 @ Mindfactory)
Video Card: Sapphire Radeon RX 480 8GB Video Card  (€268.99 @ Amazon Deutschland)
Case: Cooler Master K280 ATX Mid Tower Case  (€46.72 @ Amazon Deutschland)
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified ATX Power Supply  (€66.90 @ Caseking)
Total: €791.43
Generated by PCPartPicker 2016-07-13 14:05 CEST+0200
https://linustechtips.com/topic/625730-first-pc-build/#findComment-8075417
Total: €791.43
Any regular atx boards for that price point?
https://linustechtips.com/topic/625730-first-pc-build/#findComment-8075442
Total: €791.43
Wow, that looks great. I think i would replace the H110M with a B150 Mortar, read lots of bad things about cheap ASRock MoBos.
https://linustechtips.com/topic/625730-first-pc-build/#findComment-8075443
apparently no, cheapest one is 80 euros.
asrock is quite decent for a mobo company, biostar mobos are the one to watch out for if you're buying motherboards.
https://linustechtips.com/topic/625730-first-pc-build/#findComment-8075450
