Budget is $200. Cooler Height 160mm or 240mm AIO support.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/625511-most-compact-atx-case/
1 minute ago, narrdarr said:
what mobo are you using?
Z170X-UD5, the ATX size is standard though.
https://linustechtips.com/topic/625511-most-compact-atx-case/#findComment-8072947
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352020 This is a very popular choice among the community.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/625511-most-compact-atx-case/#findComment-8072952
Why not get the newer version?
https://linustechtips.com/topic/625511-most-compact-atx-case/#findComment-8072955
I just listed one option. Doesnt mean its the only option.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/625511-most-compact-atx-case/#findComment-8072961
Define S. Done.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/625511-most-compact-atx-case/#findComment-8072970
1 minute ago, Curufinwe_wins said:
Define S. Done.
Is it really one of the most compact? I was really leaning towards the S340 because of it's size.
https://linustechtips.com/topic/625511-most-compact-atx-case/#findComment-8072972
The Define S is about 10L larger, but still on the lesser side for ATX and it's footprint is even smaller than that (it is a pretty wide midtower thus the volume.)
The Define S is 15% wider and within 5mm of the height. Plus it is just a so much better case.
If you want to go extreme compact, there are a few lian li cases that are stupid small, but you give up quite a bit to get that.
https://linustechtips.com/topic/625511-most-compact-atx-case/#findComment-8072987
Now to decide between the ProM and the Define S.
https://linustechtips.com/topic/625511-most-compact-atx-case/#findComment-8073009
