In all seriousness i have 100% no clue whats happening I have reinstalled Windows and only a very few pieces of software and it still gets bluescreens and crashes.
https://linustechtips.com/topic/62541-pc-has-a-freezing-problem/
Have you tried without your GPU?
With 1 ram stick?
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/62541-pc-has-a-freezing-problem/#findComment-854381
With 1 ram stick?
No but all should be fine my ram is relatively new and my gpu works fine i think. it seems to happen the most when im watching a flash video but i cant be sure because it happens once in a while but its always the exact same crash. first the pc lags out for a second and the audio repeats then it unfreezes then after a second or 2 crashes altogether.
https://linustechtips.com/topic/62541-pc-has-a-freezing-problem/#findComment-854390
check for heat issues ,,,, also do some tests like memtest
it will tell u if u have ram issues ....
, and stress ur gpu  then  cpu with  aida64 come back and tell us did it crash or not
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
https://linustechtips.com/topic/62541-pc-has-a-freezing-problem/#findComment-855560
