So I am abit behind, and just got around to upgrading to kali 2016 and the rolling repos.
I did a fresh install, which went well, I did have to update the source list, no problem as the guides are everywhere.
However, I now seem to have an issue with the repos or with my apt program. Any update or upgrade takes all of 2 seconds to read, my internet is slow so I am certain it is not able to check for updates that time and there aren't packages available for anything aside from what I have installed already. I don\t get any errors, merely 'no install' or 'no package' available
Fresh install (32bit)
I was able to get java from webupd8team, which makes me think its a repo issue
Added the rolling repos to the source.list, and I can ping the site
Ran apt-get upgrade and update(again took 2 seconds to say completed)
Ran the apt-get clear and --fix-missing and dist-upgrade commands and restarted, fixed nothing
Short of retreating to 2.0 or a new install I'm out of ideas. Thanks
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/625371-kali-rolling-issue/
