Right, having just upgraded my RAM, I’ve found that my hyper 212x conflicts with the heat spreaders of my dims. So I’m going to make the jump to an AIO. I need something that is compatible with LGA1150, and will fit in a Corsair air 540 (240/280/360mm). I have been looking at an EK predator 240 but found it too expensive. Thus I was going to get a Swiftech H240x2, but seemingly most of the ones that amazon UK sells leak (based on 7 of the 8 amazon reviews) and I can’t find it for sale anywhere else in the UK. So now I’m really stuck as all of the other AIO’s seem very similar and I’m having trouble differentiating between them.
So good people of LTT can you please help me as to which AIO I should invest in?
https://linustechtips.com/topic/625323-need-help-picking-an-aio/
How about just put the 212X fan on the other side and have it pull air?
http://www.tomshardware.com/reviews/best-cpu-coolers,4181-2.html
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/625323-need-help-picking-an-aio/#findComment-8070850
I can definitely recommend the Corsair H110i GTX as a very good AIO. However, from what I'm reading, the NZXT Kraken x61 seems to best the Corsair in almost every way except looks and price. I'd probably recommend the Kraken.
I will most likely not respond to you in a thread unless you quote me.
$500 PC | $800 PC | $1000 PC | $1200 PC | $1500 PC | $2000 PC | $2500 PC | $3000 PC | $4000 PC
Damnit Carl (My portable POS):
CPU: Core i7-6700HQ
Motherboard: Toshiba L55-C5392 Mobo
RAM: 8GB DDR3 (even though I have Skylake)
GPU: Intel HD Graphics 530
Case: Toshiba L55-C5392 Case
Storage: 525 GB Crucial MX300 SSD
PSU: Whatever power jack comes with it
Display: Some 1366 x 768 garbage + an OK 1080p monitor
Cooling: Not enough + an external laptop tray
Keyboard: The included one
Mouse: $4 Lenovo 3D Optical Mouse (not as bad as you (rightly) assumed)
Sound: The Skullcandy branding right under the power button should clue you in
Operating System: Windows 10 Home
PCPartPicker URL: pcpartpicker.com/i-wish-i-had-enough-money-for-a-desktop-my-laptop-is-so-sh*t-its-not-even-on-portablepicker
https://linustechtips.com/topic/625323-need-help-picking-an-aio/#findComment-8071008
Which puts the fan opposite the rear exhaust, and working against it, creating a dead-zone inbetween. Its the config I've got at the moment but its sub optimal IMO.
https://linustechtips.com/topic/625323-need-help-picking-an-aio/#findComment-8071420
Just turn the fan around :)
The performance difference between a fan pulling and pushing isn't big
Computer Specs:
https://linustechtips.com/topic/625323-need-help-picking-an-aio/#findComment-8071444
13 hours ago, Matias_Chambers said:
Corsair H110i GTX
I was under the impression that the H110i GTX was discontinued and replaced with the almost identical ever so slightly modified H115i.
I would personally prefer the H110i (Previously H110i GT) over the H115i.
I haven't seen any evidence that demonstrates a statistically significant difference between push and pull at all.
https://linustechtips.com/topic/625323-need-help-picking-an-aio/#findComment-8074724
