3 minutes ago, AlonE said:
A quiz with one question!
What is this fan that came pre-installed in my case, AM3b socket. 4pin connecter (btw)
An AMD stock cooler fan? No?
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/624675-cpu-cooling-fan-quiz/#findComment-8063028
Maybe, It just shares ALOT of similarities with the thermaltake galaxy a1 cooler
That's a stock style cooler.
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/624675-cpu-cooling-fan-quiz/#findComment-8063073
That's the stock cooler used for a FX-8350. If you're asking for the fan model name, it should be underneath the fan.
https://linustechtips.com/topic/624675-cpu-cooling-fan-quiz/#findComment-8063125
If you look closely at the fan mount it clearly says Cooler Master.
P.S: the baseplate (where your thumb is touching) is pure copper. Oils from your hands / fingers will permanently stain the metal.
EDIT: Just looked at the tock cooler for my FX-8350 again...
It is a fan made by Delta Electronics.
  • DC Brushless
  • Model No. AFB0712VHB
  • DC 12V, 0.55A
  • Dimensions: 70mm (L) x 70mm (H) x 15mm (W)
  • Airflow: 45.5 CFM
  • Static Pressure: 0.306 in H2O
  • Bearing Type: Ball Bearing
  • Maximum RPM: 6000 (?) RPM
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/624675-cpu-cooling-fan-quiz/#findComment-8067171
