processor socket type = AM3+
motherboard socket = AM3+
So these two are compatible :)
The motherboard contains a PCI slot that is compatable with graphics cards so you are fine there too!
Great little budget build however if you are looking to overclock I might suggest a motherboard with a better power delivery, otherwise, all good! :)
https://linustechtips.com/topic/624473-compatibility-help/#findComment-8060403
Thanks! Any suggestions on a better motherboard?
https://linustechtips.com/topic/624473-compatibility-help/#findComment-8060438
With motherboards, a very general way to look at them:
Budget: £40ish
Mid Tier: £70ish
High End: £120ish
Pro Grade: £170+
-The budget grade might provide you with the ability to overclock the clock speed of your multiplier, but might not give other features like, voltage or XMP settings. Lower grade parts installed, will work but don't push it too far.
-Mid tier will provide good overclocking functions, but dont expect usb 3.1 or other expencive features. These boards are usually have a good build quality but are stripped back high end boards.
-High end boards will provide great overclocking features and have the some of the best quality parts. Good price to performance mark here.
-Pro grade, will provide the best parts, newest features and usually RGB lighting on the board. Best overclocking features and support. Will usually have plastic/metal covers on the IO and Southbridge. Some have "armor" over the main components on the board.
As you are looking at the budget end of the spectrum, I would suggest adding £10/20 into your motherboard budget to ensure you are getting the best you can for your tier. Near the bottom end of the scale, you get what you pay for. Just check the motherboard can overclock before purchasing. Check the manufactures website, it will usually be promoted on there if it can overclock.
https://linustechtips.com/topic/624473-compatibility-help/#findComment-8060567
Budget: £40ish
Mid Tier: £70ish
High End: £120ish
Pro Grade: £170+
Any specific motherboard you would recommend for 40 quid? oh and does the mobo is showed you have PCIE and if so should i put a GPU (r7 370) into PCI or PCIe?
https://linustechtips.com/topic/624473-compatibility-help/#findComment-8060610
A good looking motherboard is
 https://www.amazon.co.uk/Gigabyte-970A-DS3P-Motherboard-Socket-Express/dp/B00CX4MUCC/ref=sr_1_5?s=computers&ie=UTF8&qid=1468244429&sr=1-5&keywords=AM3%2B+motherboard
You will need to ensure it will fit in your case due to it being an Full ATX size motherboard. Looking on the Gigabyte website it says this motherboard has overclocking functionality.
https://linustechtips.com/topic/624473-compatibility-help/#findComment-8060675
Im going with a micro ATX case so im assuming this wont fit
https://linustechtips.com/topic/624473-compatibility-help/#findComment-8060682
Oh if you don't plan on overclocking then you will be absolutely fine! When i said be careful i meant that some boards have low quality parts which when pushed too far can overheat or outright break. Some motherboards don't provide voltage settings either, so when you overclock, the board automatically bumps up your voltage, leading to an unnecessary level of power being fed to your CPU, decreasing the longevity and increasing the heat output of the CPU.
However as you don't plan on overclocking, you will be fine as all boards work as they should at stock specs.
https://linustechtips.com/topic/624473-compatibility-help/#findComment-8060727
OH! it seems the mid tower case supports full atx  motherboards! i might go for it then https://www.amazon.co.uk/gp/product/B00NZHV8AQ/ref=ox_sc_act_title_13?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
https://linustechtips.com/topic/624473-compatibility-help/#findComment-8060783
However looking at the amazon reviews it says when using an fx6300 an adapter is required as the mobo has an 8 pin connecter and the cpu requires 4 pins, what should i do?
https://linustechtips.com/topic/624473-compatibility-help/#findComment-8060804
