Heres my pc parts:
AMD athlon 760k CPU
GB f2a55m s1 MB
2x4 GB Kingston HyperX 1600 MHz RAM
600w Corsair PSU
NVIDIA GTX 960 2GB MSI gaming edition
2 HDDs (1st one is for the OS and programs 2nd is NAS)
Currently legit w10 64 bit
Here's the problem - no matter if i use it for crysis 3 or just for watching youtube at some random time it shows blue screen (for problem it says some critical struction error or something like that) and restarts - works fine for some time and then again crashesh. This is happening ever since i builded it ( 2 1/2 years ago) but got rly worse when i upgraded the GPU 1 year ago - before was 1 crash every 2-3 weeks and now can make 4-5 in a day.
During this time i have used it for mostly running multiple clients of 1 old game 24/7 but things hard like crysis and etc were rly rare used on it or just sitting without doing nothing. I have tried diferrent OS and drivers but that didnt fix it.  The HDD doesnt have bad sectors.  Also one important thing  - windows programs like amd overdrive and other say that the CPU runs at 50-60 degrees but while i watch these numbers the MB alarm starts for 70+ (got new thermalpaste and extra fan same thing).
One more thing  - i installed w10 after alot of raging last week and it got new problem  - before on w7 i could easily run Assassin's screed Cyndicate on high settings lag free and now on low has some pauses if i may call it like that (the whole game pauses for a secound or two and resumes after that) and this is not just while i play but also in cutscenes witch i bet isnt involved with the GPU performance at all
Any suggestions for troubleshooting or stability tests is appreciated!
https://linustechtips.com/topic/624448-random-crashesh-help-needed/
What's the exact model of your PSU and when did you buy it ? If it was 2.5 years ago and if it is from the VS series, it might be dying and causing all your crashes. Those PSU are really bad and from what I saw, they never got past the 3 years mark so it might be the problem here.
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
its CX600 Alimentation ATX PSU got it maybe 2 years ago
As for a picture of the blue screen it maybe dificult since it totally decided to troll me and since last night it doesnt even show blue screen  - just dies and reboots.....
Is there any directory in windows that i can see those errors?
