Here is the link to my build: http://pcpartpicker.com/user/cmerr/saved/mpjPxr
I have been planning and researching for months and I think I'm about ready to pull the trigger on building my first PC. This will be used for gaming as well as work/school where I mostly use Microsoft office applications. I want to keep it under $2,000 (including monitors, keyboard, mouse, etc). I have 2 monitors listed because I intend to use one for gaming and the second for multitasking/productivity. I have not included an SSD but plan on adding one eventually, I don't think using a HDD is a big issue for now. Does this seem like a decent build? I don't have any experience so this is solely built off Internet research. The one piece I am unsure of is the PSU, is the one listed of sufficient quality and power? I also plan on adding a second GTX 1070 in SLI eventually.
Thanks in advance for your help, I appreciate any thoughts or comments!
https://linustechtips.com/topic/624370-first-pc-build-thoughts/
The EVGA NEX series are known to have subpar voltage regulation, which can put unnecessary stress on the VRMs of your GPU and motherboard. I would get a Corsair RM550x instead.
If you say you're gonna put in a SSD eventually, then the build looks fine otherwise.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/624370-first-pc-build-thoughts/#findComment-8058604
Looks awesome. The 1070 kills 1080p gaming so if in the future you are going to have two then consider getting a 1440p monitor now and then when you have two 1070s you can go crazy.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/624370-first-pc-build-thoughts/#findComment-8058627
