Double-Precision and Floating-Point Precision?!
Solved by ARikozuM,
I'm not sure exactly [on how to explain it].
In engineering, you're only allowed so much margin for error. As a result, the double precision is necessary to keep the tolerances very tight. Imagine drawing two lines on paint. You zoom in and they start to separate. If you do the same on Autodesk, the line will still be connected and if you placed an angle indication, it will continue to be as precise as possible.
Come to think of it, two applications where it will matter a lot is prosthetics where having exactly the right amount of material is important for their use and micro-machinery where using scales doesn't work well with computers.
