Triple monitor mount on a 52" desk
mattronczka
I have a 52-inch desk and I'm looking to get a monitor mount for my three 24-inch monitors. Will i be able to fit it on my desk
they would overhang the sides of you desk a bit, since each of those monitors would be 20~21 in wide, but it would work with a vesa mount
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
This is what I use. Its 105$. There is a single point in the middle were it stands. It is about 9 inches wide... That being said, you could get away with a sturdy 9 inch table if you wanted. https://www.amazon.com/Deluxe-Monitor-Standing-Supports-002-0020/dp/B006JG9RQ2/ref=sr_1_8?ie=UTF8&qid=1468165424&sr=8-8&keywords=3+screen+monitor+mount
