Hello People from the internet.
To quickly give in a little background on this, ive been planning to build a pc for a while and will be in2-3 months when i move to canada.
im 14 and i have a tight budget of $2000CAD (inc. 13% HST, and monitor) and im planning to be mainly gaming, might test youtube and twitch a bit and keeping upgradability in mind.
I will be olanning to oc later once i equip a better cooler.
Heres my build
1: http://ca.pcpartpicker.com/list/KF6sZ8
 2: http://ca.pcpartpicker.com/list/pHmr6X
i chose the g.skill ram because im digging that heatspeader and i know the no.2 build is a smarter move on money but im not sure the card will go with the white and black and a red accent with dark shades is more my theme
thanks - side note. Is vuugo a good retailler for canada. If not does ncix price match with them :)
https://linustechtips.com/topic/623676-new-build-help-canada/
If you can fit all of your peripherals you want in that budget along with the build with the G Skill, then go for the one that you like better. They both will have the same/similar performance. Vuugo is a legit retailer, but thier shipping is rather slow and thier customer service is bad and some have said that they can have hidden fees
https://linustechtips.com/topic/623676-new-build-help-canada/#findComment-8039907
Im going to be buying the cmstorm devastator kit, thanks for the info i think ill pass on vuugo if i can price match them.
Hopefully stuff will go on sale so ill go for the 1st if budget allows :)
thanks for help
https://linustechtips.com/topic/623676-new-build-help-canada/#findComment-8048466
11 hours ago, lee32uk said:
The GTX 1070 is better suited to a 1440p screen. It is a bit of a waste on a 60Hz 1080p screen. I would go with something like an RX 480/R9 390/GTX 970 depending on the prices, or wait for the GTX 1060.
I understand the 1070 is overkill but i want a card that will last 2-3yrs even if i have to turn down settings as its an amazing card. But if i had to go with a cheaper card. What do you reccomend i put my money into if i have spare :)
thanks
https://linustechtips.com/topic/623676-new-build-help-canada/#findComment-8048493
thanks
Either of these would be a cheaper option for 1080p
http://ca.pcpartpicker.com/product/J2FXsY/gigabyte-video-card-gvn970wf3oc4gd
http://ca.pcpartpicker.com/product/P27CmG/sapphire-video-card-100382ntoc2l
You also have the RX 480 and the upcoming GTX 1060 which looks like it might be a good card for the price.
I don't want to put you off the GTX 1070 if you are set on it. I was just showing how you could save some money and still get a good card for the resolution you are playing at.
https://linustechtips.com/topic/623676-new-build-help-canada/#findComment-8049363
I understand lol thanks, but in the meantime ill just wait till how much cash i have when i buy the parts then ill look at the  appropriate card for the money but as far as i know, theyre all good cards for the money :)
thanks dude
https://linustechtips.com/topic/623676-new-build-help-canada/#findComment-8053488
Accually before the launch of new cards. I was set the 970. So if the 1060 is faster than the 480 and has a beetter cooler/build quality compared to the 10 series. Ill probably go for it, as i do want to overclock my card to the max i can on air :)
https://linustechtips.com/topic/623676-new-build-help-canada/#findComment-8053518
