I would suggest either dual 240 or 280mm rads or a single 420 at the least. There is actually an old topic that has the calculations for thickness of the rad + TDP and all that jazz to give you an idea of how much space you need to dissipate heat at a certain level but I can't find it right now :(
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
6 minutes ago, RemoEST said:
Hey guys!
Im wondering how much radiator space I need when I plan on cooling CPU&GPU + some overclock. My case is Define S, so it can fit 420 up top and 360 up front.
Thanks in advance.
For a single CPU and GPU loop a 360mm rad would be sufficient but if you wanted absolute dead silence while at full load having more like say a 360mm and 240mm would be give you a very capable system even if you did very heavy overclocking.
57 minutes ago, RemoEST said:
Hey guys!
Thanks in advance.
welcome to the Linus Tech Tips forums!
you can use either a 360 or 420, but not in the FD Define S.
depending on amount of noise you can tolerate, anything from a 240x30 can cool it.
no voltage overclock can skate on a 280x60 or 360x45.
adding voltage to the overclock, 2x240x45 or 360x60 or 360x45 and 240x45.
i was only cooling a 2500k + gtx 970
just a single rad that has 360mm total was working for me
but then i got 3 units
so i could keep my fans pretty much at 600 rpm
with that much radiator on my pc.
i could actually game in the 50's
with NO fans on at all.
lol
i did not think i had any space inside my case,
so i said. TO HECK with that
and BOLTED some mounts i made out of sheet metal
Directly into the plastic back of the case.
and then for the top radiator, i used bendable steel to make "brackets"
TLDR
anything that has 120mm x3 or more should do your job no problemo
but more radiators = cooler temps
cooler temps = quieter rig
