2 minutes ago, TheHappyJarhead said:
You wont be able to stream and play on that cpu you have on any decent settings mate, you may have good enough internet but your cpu isnt up to par
Well I do know that I need to use the nvidia encoding for the streaming but Im not sure on the other settings.
https://linustechtips.com/topic/623625-obs-help/#findComment-8039452
