many people recommend 80 + certified power supply's ....
i have one laying around with Efficiency >85%@ Typical Load
so whats the difference :?
also whats the difference between dual rail  and single rail :>
in my country people just buy some cheap chinese power supply without even looking ... but i know they suck  but some people on internet say cooler master power supply's are like chinese one is it true :?
also some people know if this power supply heats up a lot and makes ur case worm  how do they figure it out : ?
thanks in advance
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
https://linustechtips.com/topic/62348-power-supply-and-stuff/
thanks in advance
the >85% @ typical load will be marketing jargon. they dont know what you'll be using and how much power you're consuming
the whole efficiency thing is helpful if you want to be eco friendly, but in the long run i dont know if you save yourself a whole lot of money..
single rails are normally perceived as being better as they distribute the current over one rail, as with a dual rail, the same current is distributed over the two, so if you plug too many things into one rail then it'll blow the psu.
dont just say that if somethings made in china it is bad, its not that. it'll be the quality of the manufacturer, not the country its made in. you'll be surprised how much is made in china
coolermaster are good PSUs, regardless if they're made in china or not.
Gaming/Engineering PC: -i7 6700K, 4-4.2GHz "Eleanor" -ASUS ROG HERO VIII MOBO -16GB DDR4 3000MHz Corsair (2x8GB) -Gigabyte Windforce 980Ti OC edition (1405MHz GPU clock) -H110i GT Corsair CPU Water cooler -980GB Sandisk Ultra II SSD -Corsair 450D ATX Case -RM850i Corsair PSU (Modular) -28” 4K Samsung -27” 1080p Samsung
https://linustechtips.com/topic/62348-power-supply-and-stuff/#findComment-851686
well i said chinese psu that are imported to my country are bad as they don't run much they blow quite often  ... thats why my experience with them is bad
https://linustechtips.com/topic/62348-power-supply-and-stuff/#findComment-852469
ok but i still dont get the diffrence between 80+ psu and normal one
https://linustechtips.com/topic/62348-power-supply-and-stuff/#findComment-853551
80+ is just a efficiency certificate, it just tells you how efficient the psu will be at certain loads for example at 50% load it might be 85% efficient, meaning maybe 500 watts of power will be going into your components but it will draw roughly 588 watts from the wall? the rest will go to excess heat and various other things, it's just a proof of how efficient the psu is, namely a efficiency certficiate.
http://en.wikipedia.org/wiki/80_Plus
if it has some 80+ rating it means it has been tested and rated, soo .. you can probably trust it, by no means trust it blindly though.
https://linustechtips.com/topic/62348-power-supply-and-stuff/#findComment-853749
