Overheating causing shutdown
Solved by ComradeVodka,
1 minute ago, nikolaizombie1 said:An h212 does not fit inside the case (trust me i tried) and some chip of some kind on the back prevented me from installing a h212 anyways so i need a back plate that is compatible with my motherboard
That's unfortunate
At any rate I recommend getting 1 front fan and 1 rear fan (maybe 1 more front fan so they can both run at low RPM). As for CPU cooling maybe a relatively cheap AIO since it's an ITX case such as the Seidon 120V or Corsair H80?
